Dropping RPM's
Gatorsbabe
I have a newly rebuilt 1978 evinrude 115 hp...new rings, bearings at all cylinders, new wiseco racing pistons, new water pump impeller, and carbs rebuilt. The motor will rev up to full throttle upon takeoff, then drop to half throttle even though the lever is still at full throttle. Any ideas??
jimmbo
Prop is sucking air then grips the water, that's one possibility
interalian
Do you mean it comes up to full speed then slows down even though you're still WOT? If so, I'd suspect fuel starvation. Try having a helper pump the primer ball in the gas line when it happens and see.
oldboat1
If you have a built in tank that was not cleaned out, you may have water in there that is sloshing around with the movement of the hull. Similarly, water in the hull can move around when underway, causing the boat to wallow.
alternatively, might have an issue with the throttle cable or the linkage.
Gatorsbabe
Interalian...yes even tho the throttle lever is fully forward, the engine drops to half throttle.
Oldboat1...not built in tanks...portable tanks that are fairly new...ball pumps up as it should.
Faztbullet...yes it has been thru the break-in period without an issue but this new issue started fairly soon after.
It does seem to idle a little low & sometimes dies at idle, but starts back up ok. Is it possible to adjust the idle up?
My next step is to pull the fuel pump off to see if there is debris blocking the screen...any other suggestions are welcomed!!!
interalian
If the carbs were overhauled, the floats could be set low. My money is still on starving for fuel. If you keep the hammer down does it come back or stay low?
Gatorsbabe
It stays low. If you pul the throttle back then push it forward again it stays low.
oldboat1
Might get a helper to drive the boat while you look at the motor linkage -- see if it moves properly with the remote lever advance.
Chinewalker
I suspect electrical - fuel issues aren't usually abrupt like that. Possibly the power pack. Check your plugs to see what they look like.
oldboat1
^^in that regard, cyl drop test that boobie mentioned above. Can use a timing gun to see if a bank of cylinders is dropping out, maybe due to a faulty pack as suggested.
If coil wiring came unassembled, it’s also possible that a spring clip isn’t solidly connecting the wire to the plug. Kind of a head-slapper, but happens.
DRCrowe
I've had similar issues with my 87 225 in the past. My engine has 2 power packs and had one fail. It would essentially shut off half the engine at higher RPM's and come back at idle. It took me a while to believe it because I thought electrical components would either work or not work, not work at low speed and shut off at high speed. Just a thought. Good luck.
Joe-1709
Hi Gatorsbabe
I have similar conditions and symptoms on my 1974 135 evinrude.
can you post how did you solve your problem please?
Gatorsbabe
Well...it's not good.
Cylinder #1 105 lbs compression 10% leakdown
Cylinder #2 110 lbs compression 20% leakdown
Cylinder #3 105 lbs compression 15% leakdown
Cylinder #4 95 lbs compression 40% leakdown
I purchased the motor 18 months ago and it was supposed to be "rebuilt", including new Wiseco racing pistons, rings, and bearings at all cylinders (among other things), but I don't see how that is possible. We started having power loss issues, stalling, etc. from the get go & went back under warranty to the seller early on and was told it was a loose screw & were sent on our way. Our last trip out was when we had the "drop to half throttle & never came back" issue I originally posted about. The boat only has about 10 hours on it since the "rebuild", since our new work schedule & health issues has limited our lake time over the last year and a half.
I have already confirmed via pictures, calls, and emails with a representative at Wiseco that these are in fact not Wiseco pistons, since they dot etch the size, model, and run # on the dome of all of their pistons. I also confirmed that Wiseco does not make "racing" pistons for old outboard motors like my 1978 Evinrude 115hp.
Piston #1 looks like a newer piston...2, 3, and 4 appear to be old pistons, based on the carbon buildup present on them and not on #1. The carbon buildup on #2 was lightly scratched off to see if there were any numbers on it & there are clearly not any numbers. The shop that did the compression/leakdown tests (where we took it for a second opinion) said they (2,3,4) look like pistons that haven't been made for 30 years. They also said that a proper rebuild that they do would include boring the cylinders to the next oversize & putting all new oversize pistons/rings/bearings in the rebuild.
When I asked the "rebuilder", he said he doesn't keep records of what size pistons he uses. He also said that a proper rebuild does NOT require boring, & that he did not have records of what bore size was used, if any. He said that boring all cylinders was also not required because there is not a balance issue with a 2 stroke. He said only honing was needed to establish a cross hatch pattern prior to piston installation.
From what I have determined in my research, the fact that the pitting is present would be an automatic reason to bore the cylinder. Low compression/high leakdown would be another.
I am considering legal action under civil law for fraud...since we paid for a "rebuilt" motor & clearly didn't get what was stated in the sales contract. My next step is to pull the pistons to have them examined.
Opinions???
jimmbo
If you are going to sue, you really need to get a reputable engine builder to verify what exactly what your engine consists of, and a good lawyer. Sue for what you paid for the engine, expert witness costs and legal costs. A civil case needs a much lower threshold to tip the scales than a criminal case. Did the "Rebuilder' put anything in writing regarding what parts were in the engine? As you probably know, verbal is less than useless.
Does this rebuilder have a shop, or is he working out of a Flea Market, I mean home garage?
Gatorsbabe
Yes, sales contract...specifically states "The motor is rebuilt pursuant to factory specifications with new rings, bearings at all cylinders, and new wiseco racing pistons. Carburator's were rebuilt during the course of the rebuild. A new water pump impeller was be installed. New controls to furnished and installed. Motor will be lake tested and a link and sync performed prior to delivery" I have email, phone, & picture proof from the manufacturer already that they are not Wisco pistons. His current craigslist ad indicates alot more work is done on a rebuild.
He has a registered business he works under in the state, but he is a home garage guy, not an established store front.
Faztbullet
Looks like it was torn down,cleaned and honed (and not that good a job at that). Measure cylinders and see how much wear is on them as he fully of crap as a rebuild brings back to factory spec and a refresh is just hone and ring., #2 and 4 are worn as you can tell by the dark areas around port. Also he honed using a spring hone and there is no crosshatching. Good luck at getting $$$ out of him.
Gatorsbabe
What about the rust color & pitting on #1 and #3...it is fairly deep. Isn't that an automatic need for boring??
