Drive wont go down
millerz28
Well got my old 230 Chris craft scorpion running but cant get the drive to go up or down solinoid clicks when I push the button but drive will not go up or down. Cant hear motor for pump running just solinoid.
Re: Drive wont go down
Ayuh,... Welcome Aboard,... Who's drive,..?? What model,..?? What Vintage,..??
TorchedGT
First things' first, run back there with a volt meter and check power going to the motor - if you don't have power (probably don't) just trace back up the circuit till you find the problem. Probably fuse, relay, breaker, or wiring problem - you might get all the way up to the switch and discover that it's right there.
