Drive shaft bearing slides
115hpmercury
Hi there,
Does anybody knows?
I'm having a 115hp 1990 Mercury
Is it normal that de thrust bearing on de drive shaft (just above the pinion wheel) is sliding over shaft? Or does it has to fit stif?
Kees
verado7
Re: Drive shaft bearing slides
are you talking about the the thrust washer on the prop shaft ?
