That's kind of where i was hoping to mount it, so my bunk is not in the way. I will post another pic. in the morning. I have not had it in the water yet to see about what the water looks like back there and none of my launches have their docks in yet.I'm guessing at a good spot being on the inner transom about centered between the drive and where it steps out. But it's hard to tell from the angle of the picture. Also hard to know (for us) is how the water breaks off the transom when the boat is on plane. Could you post a straight on picture of the transom from straight behind the boat? Maybe a down below type shot.
My transom looks similar to yours, with a step. Mine is mounted halfway between the drive and step on the port side, about 8 inches from the drive. It came like that and seems to work well and not in the way of anything.
Different situations require different solutions,
For the transducer holes it'll depend on where you drill them. Most of time there will be the transom wood there to back it up so you can just drill and screw. Make you seal them good with 3m 5200 or 4200 to avoid water intrusion into your transom wood though to avoid leading to a rotted transom. Many say the best bet is to drill your holes over size, fill them with resin, then do your mount holes. this gets you transom wood sealed with resin and in theory avoids all chances of rot. Many do the first option.
For the gunwales your best option is to use a machine screw,washer, and nut with a metal backer plate to spread the load out. another option is to use screws with a wood backer but once again you'll need to deal with sealing it up good or sooner or later you'll be redoing it due to rot.
Does using a 1/2" screw and doing the bevel for cracking filled with 5200 sound right? Do i apply the 5200 into the hole and let it dry, or put it on the screw wet then screw it in?
5200 in hole, put screw in while wet. I always try not to drill all the way through the transom, just a bit deeper than the screw.
Thanks, i think i am gonna go for it How long of a screw do you think i can use without going all the way through?
The highest possible would be in the blue line on the front the swim deck. It would not look as good as under the swim deck, but i want to make sure it stays out of the water. Would that be your choice as well?Run your wire through as high as you can stand it
