Draining the carbs
zippy83
In one of my previous threads many of you mentioned to clean/drain the carbs. Is this something I can do myself or do I need to take it in to the mechaninc? Engine is 74 Merc 50HP. I'd like to learn as much as posible myself. I did some research online but I get mostly car stuff.
Thanks
Zipp
Re: Draining the carbs
Thanks
Zipp
Ayuh,... Find yerself a Manual, if yer kinda Handy, you can learn....
Mechanicin' ain't rocket science, but ya gotta be Handy, 'n have a toolbox fulla Tools.... ;)
zippy83
I do a lot of stuff on my car So I think I can get if figured out if I can get a manual for this beast
Sea Rider
Normally you wouldn't need to drain the carbs out, being a 2 strokes consume all fuel untill engine drops dead. If winterizing for long time you need to drain carbs or if engine will be transported lying onto it's side to avoid gas/oil spills in car trunks, vans. It's just as simple as removing each carb's bowl lateral screw. Place a towel or container to collect bowl's draining fuel.
Happy Boating
carholme
If your engine is a 1974:
Service Manual P/N: 90-68647
Mercury Outboards 1966 Thru 1974 (Service Manual) C-90-68647, Mercury Marine, Ac | eBay
Parts Listing:
MERC 500 - Mercury, Mercruiser, Force, etc. Parts Lookup
Until you find an OEM service manual, here is a link to the condensed version of the Clymer manual to help you get started:
Small Engine Repair Reference Center Home: MERCURY - MERCURY FOUR-CYLINDER MODELS (1969-1989).
Download it soonest to your computer as the link is short lived.
Gerry
Home Cookin'
Happy Boating
not if you go with the side of the room that says not to run them out....
I drained mine for the first time, no biggie, except my bottom drain screw was right on top of the cowl bottom and I couldn't get anything under there to catch it.
bonz_d
Sorry but you'd never ever find me running my 2 cycle dry.
zippy83
Thanks for the manuals
A lot of those mercs had the side bowl carbs with the brass main jet cover. If you remove the brass cover (3/8" wrench) the bowls will drain. You motor should have two carbs.
robert graham
When you're draining the carbs, or any other work on the motor, always slide a rag or shop towel Underneath where you're working to catch those nuts, bolts, screws, etc. that you drop!...
zippy83
good advise... It may also be a good idea to take pictures as well before starting to take it apart
TOHATSU GURU
No harm in running them dry at an idle and it's fast and convenient. Just tickle the choke when the engine starts to stop to keep pulling the last of the fuel out of the carburetors
bonz_d
You feel comfortable doing it then go ahead. I certainly wouldn't advise some one to do it to a 2 stroke. Not going to chance burning up a cylinder or piston because of running it dry for even a second.
robert graham
Probably not much to "take apart"...just remove the airbox(intake) and look around on the bottoms/sides of carb float bowl for a drain screw. Personally, I remove each drain screw, but some folks recommend just loosening the screw enough to let the gas sorta leak out...that way you don't risk dropping the screw. One other small item, don't over-tighten those drain screws to the point you strip out the threads...that float bowl is just soft aluminum. Good Luck!
TOHATSU GURU
No possible damage can occur. Residual oil on the cylinder walls alone would prevent any damage...And that's the way we have been preaching to our customers to do it for over 50 years and none of them ever suffered a problem from it. Not that that means anything though:)
