draining rams with trim pump/ 3854030 without pressure release valve?
capeshore
older style trim pump 3854030. outdrive is in the up position, blocked up. I want to unscrew the trim lines from the rams but system is under pressure? No release valve on unit? Just cover line with towel and undo? Lot of pressure in there. Thanks.
-Dave
capeshore
Re: draining rams with trim pump/ 3854030 without pressure release valve?
Scratch that , found the pressure release . It is no visual and is on opposite side of the fuse. Flat head screw
