Re: Drain Plug Help
I am still evaluating, but this is what I have learned; The transom was repaired at some point and the bellows now covers the drain plug partially. This is not that bad as the weight of the motor and outboard is held by the stringers and not the transom. Other outboards like Mercruisers do rely on the transom. The motor and outboard are square and not off center, I measured everything.... the drain hole is off center so in the pic it looks like the outboard is off when it isn't. The motor is bolted down securely and I have plugged up the drain hole with a rubber plug. The next step is to get the engine running and evaluate... install a new tilt motor and evaluate the outdrive... oil ok, water in the oil, prop turns in both directions etc... If all of the checks out ok, I will evaluate the floor and stringers underneath. If still looks ok and repairable I will keep it and proceed. But if the motor has trouble, the outdrive is bad, I will probably get rid of it and find a better one! I am still learning as I go and thanks for all of the help! I think this boat still has a good chance of working out... I will post more when I learn more!!
Thanks!
Michael.
