- Jul 23, 2011
- 53,309
Here is the story in a nutshell.
Drive is a 1988 DP290 A hanging off the back of a modified 271C
a few weeks back, took the drive off to replace the bellows. While I was at it, going to paint it.
when I pulled the drive, I could smell a faint wiff of gear lube. then when I undid the bellows, the bellows was full of gear lube. So, I picked up a seal kit for the drive as well
dissassembled the drive, replaced every seal from the input shaft to the 4 on the counter-rotating output shafts.
Also bought a new spacer washer (the one the seal rides on) for the input double bearing box.
Each seal was glued to the housing. each seal was lightly lubricated with grease.
painted the drive with POR15 and their hardnose paint. ordered dark grey vs light grey, however that is a different story
put the drive together, pressure tested it at 12psi for about 30 minutes. all good. rotated the input shaft a few dozen times while moving the drive into forward and reverse - all good.
so, I fill the drive with oil and install the drive late last week. Oil level to the top of the flattened area on the dipstick.
Saturday we take the boat out for about a 100 mile jaunt burning fuel watching dolphins, the sunset, etc. with some friends
Saturday night while washing the boat and flushing the motor, I noticed a faint wiff of gear oil.
this morning, I pull the dipstick (you can hear the air sucking in as I unscrewed the dipstick). the oil is low
pull back the bellows and there has to be about 8 oz of gear lube in the bellows.
re-checked and the drive still holds pressure this morning.
why is it leaking out the input shaft? Is there a trick I missed?
Each seal area was cleaned, then the seals edge coated with permatex #3 when the seals were driven in.
This re-seal is kicking my butt
