Don't want to ruin 76 evinrude
Jerry H
I have a 1976 Evinrude 70hp 17D spark advance and it hasn't been started in a couple of years.<br />Any tips before cranking and what is the best manual for it.<br />Thanks Jerry
Cricket Too
Re: Don't want to ruin 76 evinrude
Jerry, welcome to iboats. First question I would ask is did you leave gas in the carbs the last time it ran? If you did I would drain it out and pump new gas in. Also don't use any of the old gas you were using when it was stored. Get a tank with fresh gas and good new oil, maybe put new plugs in it, put in on the muffs and fire it up. Once it's running you can see if you need to fix anything ie. rebuilding the carbs. The best manuals are usually the factory manuals. Good luck.
Paul Moir
Only other thing I could think of is you'll be needing to replace your waterpump's impeller. They age whether you use them or not, and the consequences of having one go bad can be devistating.
bubbakat
Good advice the only thing I would do is take some tcw-3 oil and squirt a little in the spark-plug holes to oil those cylinder walls before starting
Jerry H
Thanks for the advice , sounds good to me.<br />Jerry
