Re: Don't want to ruin 76 evinrude
Jerry, welcome to iboats. First question I would ask is did you leave gas in the carbs the last time it ran? If you did I would drain it out and pump new gas in. Also don't use any of the old gas you were using when it was stored. Get a tank with fresh gas and good new oil, maybe put new plugs in it, put in on the muffs and fire it up. Once it's running you can see if you need to fix anything ie. rebuilding the carbs. The best manuals are usually the factory manuals. Good luck.
