does this riser look ok?
Failproof
Re: does this riser look ok?
Ok for what? A door stop yes. What does the ports look like? For the cost of a riser vs the damage they can do, any question and i replace them.
yrubugn
Yeah kinda what I was waiting for...
Do these originally have passage all the way around? I have one and two that are blocked.
achris
More fish than mountain goat
It's not the outlet end you should be worried about, it's the gasket surface between it and the manifold, and to extend of corrosion blockage...
yrubugn
Mating surfaces surprisingly are true and clean..manifold side is clear and clean.
achris
What about corrosion along the inside edge of the gasket surface? If there is any sign that the corrosion has penetrated into the parent metal.... trash-can it.
