Re: Does not reach top speed
The WOT is around 4,000 to 4,500 rpm. The boat is trimmed up about 1/3 way up. The hull is very clean. The gel coat is in great shape. A few scratches, but that's it. There is no water in the bilge area. Recently, I had a problem with the wood around the gas tank. I tore it out and replaced it. I found some more rot around the ski locker area. I plan to replace that this winter. I had a leak a couple of weeks ago, but fixed it. The gimbel was worn down and rusted. Since replacing it, I have not leaks.
How can to see if the throttle plates are wide open? I have the throttle all the way down.
Before I put anymore time into the boat, I want to make sure that the engine and outdrive are working in top condition. If it can reach the 42 mpg. I plan to tear our most of the wood and re-fiberglass the deck. If I can't get it up to top speed, I'm not sure its worth it.
