does anyone know how to hook up a trim gauge
jayandzach018
1981 mercruiser 120 i already went though 2 props in the past 3 weeks. boat came with a trim but its not hook up??? there is also a small button next to the shifter anyone knows what it is?
Fishermark
Re: does anyone know how to hook up a trim gauge
The wiring is fairly straightforward... IF your trim sender and wiring is good on the outdrive itself. Many times it is mssing and/or damaged. You need to look at that before worrying about the wiring in the boat at the gauge.
The button on your shifter - is it the trailer button you are referring to perhaps? :confused:
havasuboatman
Ensign
The little button next to the shifter in the picture IS the trailering button.
You said "the boat came with a trim but it's not hooked up."
Are you saying you can't lift or lower your drive with the thumb switch on your shift lever?
Bt Doctur
If you`ve busted up 2 props I`d look into a depth gauge
