Dave-R
Thread starter- Joined
- Mar 18, 2008
- 441
On our new to us 1999 Four Winns 180 Horizion, I had wanted to take her fishing very bad. The wife was working on a new bow cover, so I thought what the heck I may just as well repack the hubs. The starboard side when felt hard to turn when taking it off. I thought maybe the brake shoes were grabbing a little until I got the bearings out and took a look at them. The inner bearing could hardly rotate, and the same for the outer bearing. The races on both were pitted and discolored. The paint on the hub was also burned slightly. I found about a tablespoon of water in each bearing, and tons of water resistant grease in the bearings. I felt lucky we made the 100 mile trip from buying the boat, without a disaster. This is the first time I actually repacked any ones that were totaled, and I have done a lot of them. I ordered new bearings and races for both sides. I always tell the wife when we pass a boat trailer jacked up on the road, that's why I have to check them often. The axel is a six lug 6000 lb. with a grease fitting out on the end. The grease comes out back by the seal. The cap has a rubber grommet that you pull to get to the grease sert. I guess I won't be able to use bearing buddies, and will keep these full. I plan on setting the hubs on my wood burning stove, and then install the freezer fresh races. I am going to grind the old races a little, and use them to drive the new ones in. Does this sound like the plan? Dave-R.
