Do your electronics blink off when you start your motor?
Bt Doctur
Easily solved by using a small AGM battery and a diode. With the diode in place TO the battery and a wire from the +12v side of the harness to the diode you will keep the battery charged when the engine is running and will not draw from it when starting the motor.
sam am I
I was lost at "With the diode in place" as I am not exactly sure where that might be? And which direction is the band on the diode relative to what? Perhaps a drawing might help?
dingbat
Instrumentation “blinks” during starting because current demand exceeds battery capacity, resulting in a voltage drop below the lower limit of the instrumentation with the starter is engaged.
Possible causes:
1. Weak or under sized battery
2. Compromised (corrosion) cables and or wiring to instrumentation
3. Compromised starter drawing excessive current
