Do i need to change my prop
Michkg2000
I have a 18 foot charger bass boat with a 150 2 stroke, 23 pitch three blade SS prop. At WOT the gps says im doing 52.5 mph but my RPM is 6200 which is to high im told it should be around 5500. Is there any thing i can do to drop my rpms and gain speed or at least keep the speed i have.
thanks
junior1113
Re: Do i need to change my prop
25 pitch ss 3 blade will bring rpms down to about 5800 and speed will go up a couple mph. what make is the motor
4JawChuck
Make sure you don't overprop if this rpm and speed is empty, loaded it may pull the rpm down to 5500 and be fine. It is better to underprop than overprop unless you only use the boat empty...like a speed boat.
What brand of SS prop?
Michkg2000
the prop says lazer II on it. And no we can have two big guys, 4 batteries, oil and gas. and some gear so i would not say she is emty.
Thanks
Kurt
