Do I have sufficient tires?
spdracer50
Hello everyone. I'm new here, I have just purchased a '95 24ft.Playbuoy pontoon with a 55 Suzuki ob. The boat came with the trailer that was made for the boat. I cannot find weight of this boat but the new ones weigh 19 hundred and change, the trailer weighs 700lbs. and my guess is the motor weighs 200 max, totalling out at approx. 2800 lbs. The tires on the trailer are hi speed trailer e rated 20.5x8.0-10 rated at 1535 lbs. Are these tires up to the job? I have a 6 hr. tow to northern Ontario where the pontoon will be staying . Thanks for your help :confused:
JB
Re: Do I have sufficient tires?
In good shape and properly inflated, your tires are fine, Jeff.<br /><br />Happy boating. :)
rated at 1535 lbs<br /> X 2<br />_______________________<br /> 3070Lbs.....<br /><br />Yep, That's more than 2800 lbs....<br />Just Don't load All the kids toys onboard before you leave......
spdracer50
Thanks folks, the boat won't be loaded with anything.
