Distributor Upgrade
brodie123
Hi All;
A couple quick questions. I'm upgrading my Mercruiser 3.7 L4, 224 I/O from points to electronic ignition. The manual shows a resistor wire - I normally would be looking for a ceramic resistor for the voltage drop. Where is this wire exactly and is it actually a high resistance wire? How do I best by-pass it?
Also, my merc manual calls for 6 degrees BTDC. The label on the engine clearly says 8. Can I safely assume the label on the engine (valve cover) to be correct? It all looks original and all the other specs are correct. (valve cover is original)
thx!!!
JonBrown
Hello brodie,
2 degrees isn't that much of a difference although I have seen this such as a California boat has different timing than a Texas boat. Due to fuel availability and or emissions. Follow the label. You may have a 12 volt system and that would not have a resistor in line. Just check your coil + and point - and if it is 12 volt it is probably without.
If it has a resistor it will be 6 volt to your coil/point . Electronic is 12volts and the coil will have to be a 12 volt coil. Hope this helps..
Jon
Rick Stephens
You can tap into the purple wire before the added resistor wire and bypass the resistor.
Davetowz
Timing spec was changed. Fuel quality sucks anymore and mercruiser changed the spec . I run mine at 6 and have had no issues. A quick search here will give you many posts regarding timing on the 470 variants. The resistor is a wire ( purple) running from the choke heater to the coil +. Make sure that you want to bypass the resistor wire bfefore you do it. If using a pertronix module the instructions are pretty clear. Can tap in before the purple wire for key on batt voltage for the module +. Make sure you dont reverse polarize the module... It won't take it for even a moment, I did, and replaced the module.
brodie123
Thank you! There is indeed 6V on the coil and I ordered a new coil along with the dist upgrade. thx!!
bruceb58
Honorary Supreme Mariner
Why get a new coil?
You got thrown a curve in a previous response. Keep the coil you have along with its resistance wire and just make sure the Pertronix module gets a full 12V before the resistor wire.
Look at this document at part B
http://www.pertronix.com/docs/instru...heets/1141.pdf
