Digital versus analog voltmeter for 12 volt system
NickMDal
Do analogs give enough information?
When running a trolling motor with a 12V AGM battery, the full charge range of the battery may only be 1.5 volts (12 - 13.5V). I'm trying to find something inexpensive but accurate. Isn't the analog needle sweep too small to tell how much charge is used and left?
Any decent digital waterproof-ish gauges for under $50? :)
bruceb58
Re: Digital versus analog voltmeter for 12 volt system
I would get a digital meter. May want to verify its reading with a multimeter though.
Not sure how much you want to spend but this is an excellent meter:
http://www.bluesea.com/products/8251/DC_Digital_Voltmeter_with_Alarm
http://www.ebay.com/itm/Blue-Sea-82...319?pt=LH_DefaultDomain_0&hash=item2c6f405dcf
Here is another that is a bit cheaper.
http://www.sailsmarine.com/ItemDetail.aspx?c=35163&t=8235_Blue_Sea_DC_Digital_Voltmeter#.Ugp9MD-CdwI
NickMDal
Thanks for the suggestions. The Blue Sea meters are quite nice but a little steep for use in a kayak :)
I cannot easily access the battery for testing with the Minn Kota. Nice price though!
Anything else, maybe under 100 that would be reasonably accurate?
dingbat
You don't have a voltage display on your sounder?
NickMDal
Don't have a sounder yet. Just bought boat and adding trolling motor kit. Do they usually have an accurate meter for battery voltage? They Minn Kota board has a couple of connectors for a voltmeter and so I thought that was the way to go.
NickMDal
Went for the Blue Sea 8235 for 127 + 8 shipping. Thanks for the tips!
dingbat
Yep, most sounders have an accurate digital display of voltage.
