did smoething retarted
Summer Fun
Banned
hi folks I started the boat today going on lake sunday [was] buttt some how prop hit ground and blew apart!!! but now what size should be on it ? i found a part that said 19 its a 1984 force 85hp what should i do maybe sell it and stay home aol thanks wayne
MGuckin
Re: did smoething retarted
way577,<br />Not retarded s*it happens. Probably a composite prop and you were a little reckless. Could have been your lower unit that you blew up!!!!<br />You don't say what type of boat the motor is on but this link might help you determine what you need.<br /> http://www.miwheel.com/MIWheel/html/products/outboard/PSearch.asp <br />Good Luck,<br />Mike
Bob_VT
That's a good reason to buy a spare prop! Even a used spare or a "Comp Prop" (cabela's has them) in case you have another episode. I carry a comp prop (very lightweight) just in case :eek: <br /><br />Bob :cool:
Summer Fun
Banned
hi mguckin its a 1984 bliner 16ft cuddy so should i buy a 19 prop is that what came on it thanks way577
Fouled Plug
Ensign
19 would be a reasonable pitch for that hull/motor combo. Try and find a dealer with "loaner" props so you can make sure your RPM's are within specs at WOT. And buy two while you're at it! ;)
