Did my lower unit get damaged?
nokiddin
Hey all.
Last fall, I was late getting my lower unit drained before a good cold snap. Afterwards I found oil had leaked from a hole just in front of the vent plug.
I had never seen this before so I was wondering if this indicates there was some damage inside from the freeze. Does oil leaking from that spot, or any others, indicate damage inside?
I have to pull the lower unit to change the water pump housing anyway, so just want to be prepared on what I need to inspect when I do so.
Your driveshaft seal appears to be leaking. It happens. Clean up and lube the driveshaft. Now replace the waterpump base, gasket and oring. It will have a new seal installed in it. Make sure you use the correct oring (there are extras in the kit), and that the base is seated completely.
nokiddin
Thanks so much for the replies.
I had changed the impeller about a month before this, I wonder if I disturbed the seal somehow when I was working in there and inspecting the housing. Anyway it sounds as if the process of changing the pump housing will fix this issue so that's great.
nokiddin
I'm in the process of changing out the water pump. I noticed that this area around the shift shaft was the area that connects to the holes where I saw oil leaking out as I noted above. Does this mean that the shift shaft seal is actually what is leaking?
Shift shaft seals do leak. They are easily replaced. I ground a 1/2" black pipe coupler into a spanner to tighten the new seal.
Dukedog
jus make sure tha shift shaft stays in place when ya pull tha seal out..................
