familyfun
Thread starter- Joined
- Feb 4, 2009
- 43
Couple of questions, I was working on a decarb per the instructions in the FAQ post. First, the reason for doing this was i'm having problems with the engine stalling with the cover on at idle. The idle relief bellow is fine already took it off and inspected and checked the gasket that is near the bottom of the midleg, everything towards the back side of the motor is good and couldn't really check to well the front side(my hands are way too big to slide in there). Replaced the bushing and water pump seals when I changed the impeller out a few weeks ago. I did notice a lot of exhaust coming from up in that area tonight when running it on the decarb mix, it almost looked like some was coming from where the powerhead meets the midleg
Is it normal too see a lot of exhaust to flow from these points in the picture??
Secondly, I ran the decarb mix for about 7-8 minutes(don't want to upset the neighbors too bad
) and let it set for about 7-8 minutes. When I fired it back up I noticed there was no water coming from the tell tale and when I got up there to shut it down the overheat buzzer kicked on. I let it set for a few minutes so it could cool down(oh yeah, I was running it on muffs but there was just as much water flowing as when I run it in a tote of water). Anyways, I filled the tote with water and in to it the lower unit went. Started it back up after cooling down and now the water is flowing better then it ever did before. Instead of sputtering water it actually has a decent stream of water flowing. It seems to be cooling okay since I can lay my hand on the heads with no problem. Surely running the decarb mix didn't do this or did it
Any advice is welcome or constructive criticism.
Thanks,
Joshua
P.s. 1988 force 125 C model
Thanks,
Joshua
