Determination of foam type?
Boomyal
If you stick a prybar into old foam and it fizzes and oozes water like a watermelon, would you say it is closed cell or open cell. What year do you think that closed cell foam came into common usage? <br /><br />I just hacked and pried all of the foam out of my gas tank well and I was about take it in and run it through the juicer. It had different levels of moisture in different places but it was definitely wet. The foam is 1975 variety.<br /><br />Those ping pong balls are lookin better and better. :D
JasonJ
Re: Determination of foam type?
It may have been either kind. I know over time even the most water resistant foam can eventually absorb water. I don't think a true waterproof foam exists. All we can do is make sure to minimize the conditions that allow for water to stay present in the bilge.
Boomyal
JJ,you mean like keep your boat out of the water? ;)
12Footer
LOL. I hear ya! My project boat was more of a waterlogged 1800lb surfboard than a vessel. I don't know how to tell the difference, except that "closed"cell forms a skin after it kicks. but cut that skin, and it's just am atter of time before the closed bubbles drink it up.<br />I'm seriously considering leaving all floatation out of her.
Winger Ed.
Originally posted by Boomyal:<br />oozes water like a watermelon, would you say it is closed cell or open cell. <br />Those ping pong balls are lookin better and better. :D
That sounds like open cell, but the 2 part closed cell can absorb water like that much faster than it should if it isn't mixed properly.<br /><br />Back in the 90's I rebuilt a 1968 21' Alum. hull that had been full of rainwater for at least 2 years. The 2 part in it the factory poured in the bow area was still fine. The white slabs of styro. under the floor felt like you were picking up blocks of wood.<br /><br />Something most folks don't do when foaming is leave a place where water can drain out or a means for a little air circulation. That's why all these floors and stryo. rot & waterlog in the first place.<br /><br />If you pour the area around the tank again, it'd probably do better if you left a hollow place under the tank along the keel so bilge water could get out and a little air could circulate. <br /><br />Ed.
Boomyal
Definitely Winger Ed, I haven't figured out how to accomplish that yet but that is a must do. I'm also going to put a drain hole (w/ removeable plug) in the forward bilge/rear tankwell bulkhead.<br /><br />I only had a small amount of foam under the tank, maybe two inches. I filled up about 3/5ths of a trash can with it and it is quite heavy.<br /><br />12footer, I wouldn't leave the foam out. I'd try to accomplish what W.E. recommended. The foam adds safety, strength and sound absorbsion. I think it would be pretty drummy without it.
Soda Pop Bottles................. :D <br /><br />Plenty of Drainage..........<br />Plenty of Ventalation......... ;)
JasonJ
Yup, never use the boat, put it in a garage, and it will never get saturated again. :D All it takes is a cover. So many people skip that little process and wonder why the boat is rotted. Water once in awhile isn't a big deal, being left in the rain and snow every day is a big deal.<br /><br />Hey Bondo, I have a bunch of 2.5 gallon plastic jugs in my basement. Yeah, they are industrial herbicide jugs, but they have been triple rinsed and are clean. While I am a big fan of foam, I may come across a project that is perfect for these jugs.
Hi Jason,<br />2.5Gal is Pretty Big, for Stuffing into the Bilge..........<br />Even in my 25'er.......<br /><br />Find some Fishing Nets,+ Build Yourself an Island......... ;) <br /><br />12oz. Soda Bottles though........<br />They'll Squeeze into the Smallest Places............ :D :D ;)
Winger Ed.
I haven't figured out how to accomplish that yet but that is a must do. [/QB]
Something I've done over the years is make fibergalss cardboard for lack of a better term.<br /><br />Put a piece of soaked down fiberglass cloth or thin mat down on a piece of wax paper layed on a flat surface. Or, you can make a tunnel by laying the stuff over a wax paper covered board. It turns loose after its set. For complicated things, make a mold from cardboard, tape wax paper over it, and go from there.<br /><br />When it hardens, you've got a thin material you can cut with big scissors. Shape/Cut it to make a roof for your ventilation space. Glue it down with resin, pour your foam, and set the tank.<br /><br />I've used the heck out of that technique, and its always worked real well. <br /><br />Ed.
