detailed maintenace info for Trphy 2502FH
Lensman
Hi all,
I bought this boat used and while I have the owner's manual and several other bits of documentation, I still have many questions. What I need to know right now is where all the pumps are and how to reach them. I have several that do not operate (freshwater, live bait well) and need to locate them for repair.
It also isn't clear how to pump out the fishwells.
Is there a maintenance manual of some type that goes into more detail than the owner's manual?
Thanks in advance,
Frank
mole2
Re: detailed maintenace info for Trphy 2502FH
You can download the manual from the Trophy parts site. Link is here:
Trophy Parts Site
In the manual will be the location of pumps, wiriing, etc. For the motor you will want to order the manual from Mercury. Here is a link to the site.
Mercury Parts Manual Ordering
Sea Schaul
Lensman said:
Hi all,
Thanks in advance,
Frank
For the fishwells, there should be a toggle switch on the far right of the dash marked fishwell. This will operate the pump. I have found that if one of the wells is empty, I need to put a drain plug in the empty well in order for the pump to stay primed. Whoever devised the scupper system and the subsequent pumpout should be fired.
