Depth Gauge for Harris Sunliner
danm125
Does anyone know where I can find instructions on how to use the depth gauge on a 2007 Harris Sunliner?
Fireman431
Re: Depth Gauge for Harris Sunliner
We need the make/model of the gauge itself. The boat doesn't make a difference. Your boat could have any one of 10 different models on it.
danm125
I'LL have to check in the morning. It's a digital gauge with a white face and appears to be the OEM gauge from Harris. It has arrows to adjust the depth setting for the alarm, but not sure how to adjust or if it can provide real time depth readings.
Fireman431
The three most common would be Lowrance, Humminbird, and Uniden. Get your model number, or at least be able to identify it from Google images and you'll be able to decipher a model number from that.
As far as 'real time' depth readings, during the setup phase, you'll tell it how often to reread a signal. I have mine set to reshoot 2x per second.
Here are the Lowrance manuals in download form:
http://www.lowrance.com/en/Downloads/Manuals/
Here are the Humminbird manuals:
http://www.humminbird.com/support/ProductManuals.aspx
Here are the Uniden manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=1
danm125
I think it is a Faria Depth Sounder. I found a manual and will give them a try. Seems like it should provide continuous depth readings.
