Delco Voyager Distributor on 5.7 OMC
bruceb58
Re: Delco Voyager Distributor on 5.7 OMC
shadbay...set the inital timing bypassed...unbypass and check your total advance to see it looks correct. That's all you have to do.
shadbay1
and to check the total advance I need an advance timing light or some of the tape you talked about...in either case if I set the initial timing at 8 then if the advance goes to 30 I should be good to go?....and that's at idle?
dan t.
No,no,no,8 initial in bypass will give you a total of 30 at 3200 with the bypas unplugged
LAC_STS
Master Chief Petty Officer
Set the initial timing to 8. Then either use an advance timing light and set it to 22 then run the engine up to 3200 RPM. The timing mark should be at 0 then.
Or if you get the tape set the timing to 8 then run it to 3200 rpm then see if the timing mark is on 30.
On the timing light that's how mine works. Yours instructions might differ a little but that's the concept.
I have the one made by actron that has the digital display on it.
shadbay1
finally got it....when I am checking the timing at 3200 this has to be under load?....the engine rev's fine when it's not in gear
shadbay1
ignore my last message....I bought an advance timing light....
LAC_STS
The digital advance timing lights are worth the money in my opinion. Mine can be a shop tach too.
bruceb58
No...it doesn't. distributor has no idea if you have a load on the engine.
shadbay1
so I set the base timing so that when I remove the bypass it advances to 8before....then I ran the revs up until the timing returned to 0...checked the advance and it was at about 22....I reached that advance at about 2500 rpm...then I took the boat for a run...everything works good but I'm only getting 3200 at the top...the spec for the motor is 4200-4600 so I've still lost my top end...am I still doing it incorrectly?
LAC_STS
What do you mean you ran the revs up and until it Returned to 0 hen checked the advance.
I'm not sure about your bypass but you need to set the initial timing to 8. I imagine you set the bypass then set the timing to 8 then undo the bypas.
Then in N run your engine to 3200 rpms. Then set your timing light to 22 and shoot the timing mark. It should be on 0.
You need to see if at 3200 rpm you have 30 degrees of advance. 8 degrees initial plus 22 advance.
So if you set your timing light to 22 and shoot the timing mark while the engine is at 3200 rpm it should read 0.
bruceb58
No..this is incorrect. He needs to see 30 at 3200 RPM.
LAC_STS
Yea if he's using an advance timing light and he sets it to 22 the timing mark should be at 0 at 3200 rpm.
Adirondack
No, if he sets the timing light to 30 the mark should be at 0 at 3200 rpm. Here's the easy way.
distributor loose, and in regular run mode. Start it up with your timing light set to 30. Run it up to 3200 rpm and rotate your distributor till the mark is on zero. Done! tighten the distributor and test. If your distributor is in the correct advance mode when you check your base timing at idle it should be somewhere in the neighborhood of 8. Give or take.
LAC_STS
Is this different with a points dist vs this delco one?
I was told to do it on my IGN (which is a points dist) the way I described.
On mine Im aiming for 29 degrees at 3K RPM and 8 degrees initial. When I put my timing light in advance mode and set it to 21 it shows at 0 on the timing marks.
dan t.
forget about the 22, set the initial to 8 in bypass,this will give you 30 total with bypas un hooked . simple, fool proof, you are making a mountian out of a molehill.if you want to check the total set the light to 30, rev to 3200 it will read 0
shadbay1
lots of lively discussion on my behalf...thank you gents...I think where I'm getting hung up mostly is that the instructions I have with the distr kit tell me not to do it that way....and in any of the three base timing settings they recommend maximum advance is reached somewhere between 2400 and 2800 rpm with max advance of from 21-28 based on which intital setting is used in bypass....I'm hearing differently from you....I bought the kit online...maybe I rec'd the wrong instructions?...I've been looking for some specs for the engine online but haven't had much luck
LAC_STS
Do you have an OEM OMC manual or a aftermarket (Seloc) manual?
I ask because I have the Seloc and it does not tell you in there what the total advance should be. It only shows you what the initial should be.
I ordered an OEM one but the guy on ebay never sent it so I am disputing it and will have to order another one.
You should get an OEM OMC manual. The aftermarket ones suck big time.
Maybe the OEM one will say what the advance should be.
shadbay1
I purchased a Clymer aftermarket manual...no reference to total advance only initial...for the points distributor of course
Adirondack
I think everyone is getting caught up in symantics, and different methodology to acomplish the same thing. Timing an engine with the right equiptment is one of the simplest procedures.
Shadbay, just put the dist in base timing mode. With your timing light set to 0 advance set the timing at your OEM base timing (I think 8 degrees was mentioned) using the marks on the timing cover. Your timing is now set. Put your dist into run mode. Now if you want to check your advance run the engine up to the specified rpm, and adjust your timing light until the mark goes to 0 on the timing cover plate. Read your timing light, and that is your total advance. If it is incorrect change the distributor setting and retest. Once your base timing is set you should not have to touch that. Just get your dist into the right mode for the specified advance for the engine.
Base timing, and total advance shouldn't be any different no matter what distributor is in the engine. 28-30 degrees is usually a good number for a small block.
shadbay1
thanks everyone...was out on the water yesterday and didn't have time to do any more tinkering...one nite this week I'll try again....cheers
