Deep Fried Turkey Breast??
macsfriended
Have not tried to deep fry a whole turkey. I'm a thinking I will try a turkey breast. Main reasons are to start small and make small mistakes instead of big ones; can use a smaller pot and much less oil; probably less risk of big fire or other OPPS.
Any good recommendations, tips, etc. from experianced turkey fryers?
Re: Deep Fried Turkey Breast??
Had it over a friend's house, who was experienced with it. The meat came out very jucy, the skin was like bacon. If you are a skin lover, deep fried might not be the way, I could care less about the skin.
Put the bird in the pan and then add water to the correct amount. (While the bird is still wrapped) in packaging, so when you remove the bird you can see how much oil to add to the pan to get the correct amount and not over fill it.
I remember he kept checking the thermometer and adjusting to keep it within a certain range.
Good luck!
eavega
I think the breast just won't cook right. There is a bit of science involved in cooking a whole turkey in a deep fryer. Part of it is the oil being able to evenly heat the entire turkey. The body cavity definitely makes a huge difference; frying a turkey takes 3.5 minutes per pound. Cooking a chicken takes almost 9 min per pound. The difference is that with the turkey's larger cavity, the oil has more room to circulate and cook from the inside as well as from the outside. I don't know how just doing a breast will affect the dynamics of the cooking, and cooking time may be off. I guess you could try, but if it were me I'd experiment with a whole, smaller turkey, say an 8 Lb bird, rather than just a breast. If you use that 3.5 min per pound for an 8 Lb turkey, you are ready to carve up the bird after less than half an hour. If you mess it up, you are only out a half hour of your time, so plenty of time to get another one in the oven. If it turns out good, you can do a second one in the same oil which will go much quicker since you already have it up to temperature.
With respect to setting anything on fire, just be sure you have a big enough fry pot such that when you have the bird in with the oil, you are absolutely no more than 1/2 to 2/3 of the way up the pot. Use a high smokepoint oil. Peanut oil has always been my choice because it is available in large quantities, and imparts a pleasant flavor on the food. Regular vegetable oil is not the way to go, as that has a relatively low smoke point. I cooked one turkey one time in liquid frying shortening (what you get for asking someone else to pick up the oil), and although the bird cooked well, it really didn't taste as good as my peanut-oil fried birds.
It really just takes common sense to not burn yourself, the turkey, the house, or anything else; set up your fryer outdoors away from anything flammable, have a chemical extinguisher nearby, make sure the bird is dry as possible, wear an apron, close-toed shoes, a good fire mitt and eye protection when dunking or retrieving the bird. Dunk and retrieve the bird slowly. If you lower the bird into the oil too quickly the water in the skin will vaporize to steam and cause the oil to bubble up and out of the pot. If you remove it too quickly without letting all the oil drain you will end up with a greasy bird not to mention dripping really hot oil all over everything. Be meticulous about controlling your temperature and your time, and you will have a perfect bird.
Rgds
Eric Vega
Bob_VT
Do it outside....... and make sure the bird is completely thawed out.
While I was in the mid-west I was introduced to frying my wild turkey on the stove and that was good too.
mables
A well thawed and dried bird and slowly lowering it in will result in a safe and tasty way of cooking, and in my experience it is better to leave the skin on as if you don't then the outside will brown and become hard but if the skin is there then you get the skin fried so it makes it much better tasting. 90% of all turkey fires of the result of someone taking the bird straight from the freezer and dropping it in the hot oil which everyone should know what happens when you put water on hot grease then the grease boils over and catches fire and voila ruined holidays and possible injury. So when you take it out dab it down with some paper towels and get it as dry as possible then lower it in about 1/2-1 inch at a time until the sizzling has settled down then another inch or so and so on and you will be fine.
PiratePast40
I'll chime in and agree with the others in that it's no big deal to do a whole turkey. You can get fancy and experiment with different marinades and injections later but I'd make the first one simple. It's really not hard at all and tastes fantastic.
Biggest thing is keeping the oil at the right temp. If it's windy or rainy, that can be a challenge.
26aftcab454
I have fried 100+ turkeys for friends & family-and plenty of breast ---350degrees-3 1/2 min per lb--DO NOT LEAVE IT UNATTENDED--best to have a Turkey Fryer Pot-wear long sleeves& gloves and eye protection.Slowly lower into pot.
turkey must be fully thawed and dry before it goes in the pot.
we inject orange juice(no pulp)/butter/ cajun spice mixture into several breast locations and plug holes with tooth picks.:cool:
Edko
For emphasis, DO NOT use a frozen Turkey. Thaw and dry. You can probably youtube some results using frozen. It ain't pretty.
sasto
Just the breast? Yup, do it frequently. After eating deep fried turkey, we eat it no other way!
lncoop
I've fried a few and find that each one I fry turns out better than the last one. It has been my experience that brining is critical, especially in your case since you're only doing white meat. Will it still be good if you don't? Sure, but brining just makes it exponentially better. It also safely accelerates the thawing process. I'll be happy to provide you with my brine recpie if you'd like. There are plenty of good ones avaliable on line as well. Injecting the solution of your choice makes it nice too. You can use just about anything as long as it includes butter.;) Finally, the prescribed method for measuring the amount of required fry oil is to put the turkey in the pot, cover it with water, then remove the turkey and make a note of the water level. Not sure who invented that procedure, but it's bull butter. Once you remove the turkey you have to dry it and the pot thoroughly, otherwise you have water+grease=BAD! Instead, put the turkey in and cover it with the fry oil, then remove the bird while the oil heats up. Works like a charm and is easier and safer. Also, a few strategically placed newspapers, paper sacks etc. will prevent a greasy driveway stain. Happy fryin'!:)
Limited-Time
Frying time for just a breast is 71/2 min a pound. Here's a great link for frying information.
perchin
Just the opposite here.... it makes everything taste like white meat..dry...
I'll stick to my wifes 8hour slow cooked, babysat, continually injected, continually basted...;)
eavega
I always enjoy watching this guy (Alton Brown).
He had a whole episode devoted to deep frying a turkey.
I saw the episode. I think his brine used sugar, which is a bit of a no-no when frying turkeys unless you don't want to re-use the oil, not to mention it turns the bird black.
I also saw the elaborate contraption he made to lower the turkey into the oil. While I am all for safety, that setup is just a bit over the top.
Rgds
DECK SWABBER 58
Any good recommendations, tips, etc. from experienced turkey fryers?
This makes perfect sense to me.
My first deep fried whole turkey was a big one. It did not go well....:redface:
I first put the whole turkey in the pot and filled it with water. Then I marked
the pot for the oil level with the turkey in the pot. WRONG!
It was raining that Thanksgiving so the fryer went in the garden shed right
next to the 500 gal. propane tank. The oil was hot and I started lowering
the turkey and UH OH, somethings wrong here.:eek:
My buddy who was helping and I looked at each other, should we run or
keep going? We kept going and after a fair amount of excitement we decided
that a call to the fire department was not going to be necessary so we sat in
lawn chairs, drank beer and watched it cook and all was good. :p
DaNinja
A good example of what can go wrong with frying a turkey...
Fryer dangers
Still a great way to cook a bird. I'm sold on it!
My FIL is a pro with the fryer, but when he fried the bird in the garage a few years ago (cold, rainy day in Iowa), I was a little wary.
lncoop
Rgds
I love AB. Only one worth watching on that channel in my opinion. I agree the turkey lowering apparatus was overkill, but I think it was more for entertainment value. He does tend to go over the top. Come to think of it, that may be why I like him so much as I'm bent in the same direction.;) As for the sugar, I've done 1/1/1 (c salt/c brown sugar/g water) for years with no blackening.
bassman284
Fryer dangers
Reminds me of a few years ago when my nephew-in-law, also a fryer pro, was frying the turkey. Temp in low 30s, very overcast and windy, no rain but threatening. Can't beat November in Iowa.
When it came time to extract the bird, NIL was just starting to lift it out when we got hit with a sudden, heavy sleet storm. Just like a cloudburst of ice pellets. The oil just exploded. I grabbed the lid and shielded the oil as much as possible until it settled down. We got by with only a small grease fire and the bird was fine. Took a while for the heart rate to come down though.
Silverskeeter
We also deep fry....alot.Fish ,chicken ,turkey,shrimp.I do know that the steam is flammable and this creates alot of problems because the grease is also evaporating..Be careful to not let the steam get to the burner it will ignite ! A very light breeze is always preferred when we cook it carries the steam away from the flame !Good luck,don't rush and be safe !
