MacDaddy21
Thread starter- Joined
- Feb 16, 2011
- 280
I have an older Lowe Line 16ft V-bottom aluminum boat that I want to deck. I just finished rebuilding the 79 merc 40, and want to get a deck started. I have searched online for answers, but I have not found anything truly suiting. My boat is going to be used strictly for fishing, so keep that in mind. I am also a college student at Texas A&M, so I am on a bit of a budget. I have discovered the horrors of using Pressure Treated wood, so I will stay away from it, and lastly, I cannot afford Marine Grade plywood, so here is my question.
Can I use tradtional plywood, coated in a deck sealant, then completely covered in fiberglass? I would then top it off with some paint and/or vinyl flooring. I just want to know if this is a working solution that will be effective and prevent the wood from rotting or absorbing any water.
Thanks
Thanks
