ChilliSpoons
Thread starter- Joined
- May 19, 2020
- 12
I just bought a Force outboard with a 9.9 cowling but was told that it’s really a 15hp motor. I can’t figure out from the serial number what it really is???
Serial #OE045318
Tillotson Carb F01B322
After going for a blast attached to my 12’ aluminum I wasn’t really getting the performance that I’d expect out of a 15. It ran and started fairly well but with some slight idle issues. I’ve now added a full can of SeaFoam to a gallon of gas and ran it in a test tank for about 10 minutes. Let it rest for 15 then ran it for another 10. Quite a bit of smoke but appears to idle better. I’ll do this again in a few days as well as spraying some SeaFoam into the carb. Afterwords I’ll change the spark plugs with a fresh set then attack the leg oil.
It currently has NGK BR6FS plugs. Are these the correct plugs??
Thanks,
ChilliSpoons
Serial #OE045318
Thanks,
ChilliSpoons
