kstrongsyj
Thread starter- Joined
- May 23, 2006
- 19
Morning oh great gods of the boat! Disclaimer, I am not a mechanic, but I claim to be one in my own head. I can take apart and fix anything with the right guidance and mentorship. That said, I am looking to the forum for help with my Sanger V210 (Mercruiser ECM 555)
Last trip out to the lake I code the dreaded "beeping" codes. Got my hands a scan tool and here are the results (I have changed the order they came off the scan tool based on at what "hour" point they were logged.
Boat currently reads having 325.3 hours (interesting because my dash display only shows 318...)
PCM Faults:
94 - Pitot Pressure (Boat Low Speed Sensor) Low: I have had opportunity in the past with my sensors out back getting clogged with crap from the Delta. When this happens the speedo stops working. Clean them and speedo works fine again. Guessing this is not important?
75 - Fuel Level 1 Circuit High: Never had an issue at all with fuel gauge or knowing how much I have? Again, is this even a concern?
119 Steering Position Circuit Low: I currently have the steering helm and cable out - long story, not relevant here...
Freeze Frame Memory:
21 - ECT Starboard Head Temp Overheat (56.8 hours): I bough the boat at 68 hours...given this code is so old is it even something to think about at this point?
3 - Sea Pump / Block Low Pressure (249 hours): 75 hours ago on the boat...that would have been last summer at least? Last year I had my ballast system break while driving and flood the engine compartment. Boat shut itself off, we found it and pumped the water. Ran perfect immediately after. Never thought anything of it till now.
323.9 Hours is the log time on all these....
37 - Sea Pump / Block Pressure Low: I believe this one to be the primary of my current problems. Looking for advice on this one in particular...
19 - Max RPM Exceeded: I went WOT on the lake and that is when the annoying/intermittent "beep" went solid. I immediately shut down the boat. When I restarted it ran perfect but I limped it back to the trailer and started this process of research.
9 - Engine Guardian Limiting Power: Obviously a result of code above.
151 - Fuel Pump Relay Circuit: ???
325.3 (current hours) is the log time on these ones:
75 - Fuel Level 1 Circuit High: Never had an issue at all with fuel gauge or knowing how much I have? Is this even a concern?
94 - Pitot Pressure (Boat Low Speed Sensor) Low: ???
119 - Steering Position Circuit Low: Again, I currently have the steering helm and cable out - long story, not relevant here...
152 - IAC Output: Book says Open Circuit to IAX (Wiring Problem or Bad IAC). What the heck is an IAC?
So that's the story. I believe the only things I am concerned about are the ones I highlighted in red, but I am looking to the experts for advice so I thought it would be good to include them all. Looking for help on next steps (order sensors? If so which one?). I have read about cleaning out the sea pump but not entirely sure where to start on that? Thanks in advance!
Keith
PCM Faults:
Keith
