Dating an Orlando Clipper
grizzy67
Looking for any info you might have to help date a new to me aluminum Orlando Clipper. After scouring the web I've come close but not sure of the correct year and model. This will be my restore project this summer. The aluminum needs some TLC on the exterior, seat cushions, dash, control cables and transom rebuild.
The info on the rear says 56-14-9xx. on the dash a plate gives the serial number and max of 50HP. Transom is 56" wide, 14" high and the beam is 68". Inclosed hull with windshield. The last registration in 1999 said it was a 1975 year but looking over the brochures makes me think it would have been fiberglass if they even made boats in that year.
The webpage with the photo's of the boat listings is missing the years 1963-1964 and I haven't found any listing of similar boats in those years. Any help would be appreciated.
Thanks,
Grizzy
Fun Times
Re: Dating an Orlando Clipper
Hi there, welcome to iboats!:) Any chance of you posting some photos of your boat?
kfa4303
Banned
Hi Grizz. Welcome to iboats. I'm a native FL guy and I love those old Orland Clippers. Glad you're keeping her alive. This link may help you date the hull. Keep us posted on the progress.
Orlando Clipper - Classic Boat Library
jbcurt00
Based on other iboats Orlando Clipper threads, the transom number references a model #, not it's year & length. So a 56-14-9XX, is a 1958 Zephyr:
But the listed dimensions don't match yours.
grizzy67
Thanks for the warm welcome Guys. I did some measurements again and found the following. Length is 14'4" and the transom is 15"or 15 1/2". Still looking at the model/year photo's I don't completely find a perfect match. Wish the 63-64 years were there. I've attached some photo's hope they come out good. I do have the windshield whole but a bit foggy.
Thanks
jbcurt00
I don't know, but I think it looks like the 1958 ad:
Seat back ^^^ and layout looks the same as yours:
attachment.php
Artwork may be reversed in the ad pix, or they may have offered it as both a right & a left hand helm/steer
greenbush future
Nice looking tin ya got there, I truly love the polished alum. look. These older but simple boats have more style than many of the newer one's. What are your plans for her?
grizzy67
I'd agree that the Zephyr seems to be the only name associated with the 56-14 number. Right below the Zephyr's in 1962 is the Dix. This seems to have the correct measurements but then again it doesn't show the HP that year. Orlando Boat Co. didn't seem to have a consistent numbering system so it's very confusing.
Thanks for the help guys. Anymore help is greatly appreciated. I will have to replace the wood and inner sheet of aluminum of the transom. The two piece cap on the transom will be interesting Quite a few nuts and bolts are not Stainless Steel so they are rusting. Lights and cables and she will be ready to go
grizzy67
Update on my rebuild,
Well so far I've removed the transom and associated rivets, bolts and braces. Removed all cables, brackets and metal screws. I'm having a hard time removing the steering wheel which is froze in place.
The Stern may look fine in my photo but I'm not sure what the other owners used this boat for. The rear bottom has been scraped repeatedly on rocks or beach. The right side rib has been colapsed It will take some time but I will rebuild it back up or replace. I've used a hammer and block to bring the metal back to shape.
Transom plywood is cut, glued and ready to install. I can go on and on but in short, plenty more to do but it will be a great little boat soon this summer.
I'll take a few photo's to post soon.
PS:
Any info on Orlando Clippers is appreciated!
grizzy67
Transom was in rough shape
grizzy67
No Title
some pitting and holes to be filled on the stern.
grizzy67
No Title
The rough rib to be repaired. Any suggestions or comments appreciated!
orlandoclippertim
Hi Grizz-
Your serial number is letter-punched faintly on the lower right corner of the transom near the bottom. ALSO it is repeated ON THE BOTTOM SKIN
about 1 or 2 feet forward of the transom one.
I couldn't see your damaged rib picture- I just get an X where the pic should be.
Mine had a damaged rib too. My rig was broken at each end where they messed up when they set the last rivets. I took it out and made a new rib
and re-riveted it back in. Not easy - but I did it.
If you can PM me a pic of your rib maybe I can give suggestions ?
Tim
jbcurt00
Tim
Please refer to the forum help link in my signature below
Inactive topic, it's been over a year since Grizz updated this topic, after 90days w/ out a new post by who ever started a topic, they are for research like a library book, not to be written in.
