goastrider
Thread starter- Joined
- Jun 22, 2005
- 4
Hello, everyone, I have several concerns for the yoda's out here! I just bought a 17.5 smokercraft with a 1984 rude 115. I am noticing a thick blackish oily goo running down from the bottom of the top motor casing when the engine is put in a vertica position after pulling it out of the water. The engine seems to run fine though there seems to be some vibration at high speed, changed prop no change. <br /><br />With engine cover off I do not see any source of this goo. The plugs are slightly fouled with oil and light carbon. I have drained the main tank and am using 50:1, I also have run it on a new 6 gal tank with 50:1 and get the same problem. Total amount of goo would be a tsp or two. The area around the heads seem clean and the air intake on the carbs are some what clean, there is a fine coating of clean oil each time i run her. ( some one told me it's a stuck reed valve ) Could this be the source of both oily messes.<br /><br />I am also getting a leak from the tilt hydrolic lines each time i take her out. I have replaced the two bottom orings and it has slowed down but the main leak seems to be the fitting on the bottom of resouivor ( can't get to it with out pulling whole tilt/trim unit out.<br /><br />aside from these I am very happy with my old rude. I will need to get some smart tabs though as she porpious pretty bad above 25 and drops off of plane at 20.<br /><br />I thank all of you in advance for the work your brain cells will do in helping this confused boater.<br /><br />Boat is operated at a lake at 3,600' if that helps or not.<br /><br />It's long but I hope i have given enough info to get some ideas.<br /><br />Thanks again
