artificialreef
Thread starter- Joined
- Feb 21, 2009
- 504
Hi Folks, I just received my used snap on dwell meter from flea bay and went to set the dwell on a 1983 mercruiser that i just rebuilt the carburetor on and the motor wouldnt turn over. Traced it down to stripped threads on the solenoid to the starter. Loose connection. I really hate to pull the starter because of a stupid copper stud stripped. I guess my question is?
1. The stud is 7/16 14 0r 16 thread. Copper being a soft metal. Is there a manufacturer that makes bolts that would self die themselves to this stripped out stud?
2. The starter looks like a beast to get out but the solenoid is sitting right on top. Can i just pull the solenoid and put a new stud in since it works fine.
3. If i can just pull the solenoid out, when i remove the two attaching bolts are springs going to shoot out and into the flywheel housing? From what i got on the first start, its allready purring like a kitten (adjusted the dwell twice, would like to do the timing) .
Thank you in advance.
Artificialreef
Artificialreef
