damaged shift shaft?
mechanos96
Replaced water pump and shift cable today. All went fine until re-installing the lower gear housing. Housing would go except for about a 1/2". I tried to use the bolts to snug it up but it became pretty tight and heard a little "pop" sound. I removed the housing and upon inspection noticed that my shift shaft didn't turn freely anymore. I'm afraid I damaged something in the gear housing. Anybody have any ideas?
Bt Doctur
Re: damaged shift shaft?
You wont like them,you may have broken this part
mechanos96
I believe that I may have bent that part, it still shifts. Can a mechanically inclined person change that with normal tools?
Bt Doctur
Scale 1-10, it`s about a 8
Special tool to remove/install carrier lock ring, Special tool for shift shaft bushing(you can make one)Dis-assembly straight foward .Special too to hold driveshaft (you can make one)
check your measages.
mechanos96
Looks like major PIA. I can count major mistakes I've made in my life (mechanical that is) on one hand..but this is number five. I guess I'll be making some special tools.
Thanks for your help.
mechanos96
Talked with my local boat repair guy, he says "Ive seen alot of them that have stiff shift shafts, don't worry about it" so I put it back together and it shifts great! Freaked about about nothing i guess?
