First post on the forum here, Ive been reading it for a while now. I read the sticky's on how to fix fiberglass cracking. This is my first boat, I am a total newbie when it comes to all things boat. Had a little extra cash so bought my first boat. $2000 for this 1986 335V Comanche 17 ft Ranger. I figured I would buy a beater so my two fishing buddies and I could finally get off the banks! Well, I admit, theres alot to learn about boats and boating and I had been cramming for weeks before I bought this boat. I didnt cram enough. The motor is a 1986 Johnson 120hp VRO V4, disabled VRO1 original motor for this boat, one owner. This boat hauls butt on the water and the motor runs strong!
I found some things that were hidden upon my first couple inspections and overlooked in my excitedness in getting a boat. haha. First, I want to thank anyone who responds to this forum post. I have been reading tons of posts here, and the members of this community are astounding! Two weeks ago I knew nothing, absolutely nothing about boats, except they are fun to ride in and fish from. I knew about as much about boats as any of you know about brain surgery. Now I feel I know just enough to be dangerous.
First and foremost, I will start off with a reference picture of the transom area so you know exactly how I am orienting my camera for these pictures, and the arrow pointing to where the closeups will be:
Now here is a closer shot laying on my back shooting straight up. There is some sort of metalic "shoe" or motor mount the motor is mounted to. Its looks to be digging into the transom pretty good in only this corner:
And here is a super closeup where you can see much more detail:
Now, the other side of this mount looks fine. I knocked on the transom all over and it sounded uniform in density, and there are no cracks or other anomolies i nthe transom that I can see on the outside. I put pressure on the transom using the trim while the lower end kickstand was in place for a second and the transom didnt budge, the motor is 470lb's and we put alot of weight on it and the transom didnt flex a bit.
So that is the biggest issue there.
Next up is the Deck. The carpet was bad so it was yanked out... But it revealed some cracking on the deck. The deck is solid, no soft spots, not even around the drains, its all super hard and solid, just a little cracking. These cracks are on both sides of the boat on the flooring in the exact same spots, so I only took pictures of one. These cracks have no soft edges, are sharp, and appear to have been there for a long time. First the reference picture:
And the closeup:
Looks like it cracked right through the fiberglass.
And finally Some old transducer holes in the transom:
Now, on to my questions.
THE TRANSOM:
My main concern is about this transom. I have no clue what I am looking at but it seems like the motor mount has bit into the transom pretty good there. I dont have any specific questions about this one, because I am unsure of the terminology and Whats going on, so any info would be helpful. How bad is the damage here in this motor mount area? The other side is fine just this bottom corner.
The FLOOR CRACKS:
I have been watching video's about fixing cracks (sanding and glassing, etc), but non about cracks this big. I think thats a bad thing. My question is, can I get away with some West System Repair Kit 105-T (105 resin, 206 hardener and 406 filler with fiberglass paper) to repair these or would I need Fiberglass heavy woven mat? I guess my questions are, Is it worth fixing these if I am keeping my boat covered? What would be the best materials (fiber type/resin/hardener/filler) to use to fix this to last around 3-4 years max? COuld I just make a paste out of West Systems 105 resin/205 hardener/404filler and glob it on, smooth it out, let it dry and sand it down, or should I really use fiber layers? Does this indicate a strong collision, or just hitting hard waves for years? Rotted stringers? There are no stress cracks on the cap or hull in these areas or any other areas I saw at all, just the flooring. Hull look great but there are a couple dings down there that I am confident I can take care of with a west patch kit.
SCREW HOLES:
Last but not least, Transom screw holes. Looks like someone piped silicone into them then screwed in some SS screws. I read on the forum that West 105 and 404 peanut butter consistency is best to fill these the right way. Would I need hardener? 105/205/404 and shoot it in with those drugstore type kids medicine syringes? If the boat is worth it, I want to do things the right way.
All in all, I only payed 2k for it. And it does float and runs like a champ!.. So I might get a couple days out of it before it sinks but I would like it to last a couple years at least.
And finally, I apologize if I used any terminology wrong - like I said, I know nothing 2 weeks ago and now I know just enough to be getting stressed out.
Thanks again for any replies! If you need more pics, just ask, I will post more tomorrow night.
And the closeup:
THE TRANSOM:
The FLOOR CRACKS:
SCREW HOLES:
