Cylinder Head help Johnson 1978 115HP V4
RNYC Boat
A very pain full day, just got the engine to run and then it would not start had my son pull the plugs and found them soaked in fuel. cleaned them and dried them and my son cross threaded the #4 cylinder plug threads. I have a good idea, head change I am just hoping that maybe since the last time I worked on a two stroke engine that someone has come up with a thread insert for these type of problems, are there any inserts to repair the threads or is it a head change?
Question two where in the heck can I find a cylinder head for this engine?
ezeke
Re: Cylinder Head help Johnson 1978 115HP V4
I have some, look near the top for small part numbers stamped inside a small circle. They should be a matched pair, so you need the same part # or a set.
Most salvage yards will have some used ones on hand:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
RNYC Boat
I will check for the part number How much would you let yours go for?
RNYC Boat
The part number is 324528 then there is a D3 there also.
RNYC Boat
Well it was a good day at the home front, The thread repair kit from the parts store repaired the theards with no issues
Thanks guys
