cutting floor
jelli
i want to add a bilg pump to my 15 foot boat i cant remove the floor becouse of the screws being rusted how should i go about cuting a hole in the floor with out too much trubble or cutting something i shoudent any ideas about getting the screws out
thanx
HAV2FISH
Re: cutting floor
Can you drill out the screws? Can you use penetrating oil to soak the screws?
Dick Sorensen
Re: cutting floor
The most obvious answer to how you should go about cutting out your deck (floor) is "very carefully!" ..... I did mine using a handheld grinder with a gutting wheel and very, very carefully plunged it into the deck...kept checking to make sure I didn't go too deep. Worked find....good luck.
paw2000
Re: cutting floor
How about determining the best place first, try locating any bracing or bulkheads by using a very small drill bit and wire to see if its clear underneath. After that get a deck plate and make the hole that size. that way when your done with the pump, you can use the deck plate to cover the hole. I prefer the screw type covers as they are nearly water proof, the pop out type can pop out and leak.
To cut the hole if the deck plate idea is used, the best way to cut is a thin blade jig saw. if its wood or fiberglass that would cut the easiest.
mhg
Re: cutting floor
start with a 1\16" drill bit in the center of the screw head
go slow and use some oil for lube
then move up in drill size until the head comes out with the bit
then just lift the panel up
Mike
109jb
Re: cutting floor
I've cut the deck in boats using a circular saw with the blade depth set to barely penetrate the actual wood deck material. This way the base plat of the saw prevent cutting too deep.
