tinkertinker
Thread starter- Joined
- Jun 8, 2007
- 50
As a way to give back to this community, I'll share some mistakes I made building my own aluminum canopy / tower.
I wanted a strong frame to support my tarp in snowy NY winters (no garage) and also provide lots of attachment points for overhead rod storage and side rod holders.
I ordered 1" schedule 80 aluminum pipe from onlinemetals.com and cool tinker-toy like Kee Lite fittings from Simplified Building Concepts. Lots of measuring, easy cutting, and a bit of filing the sharp pipe edges. Just an allen wrench and some threadlock to assemble. So far so good.
The bad:
I made the tower too tall, without cross-bracing, and it wobbled horribly underway. It got it's own rhythm going. It is better now that it is shorter, but I'll have to think about more bracing without making it look more stupid.
Using 1.32" sched 80 pipe was overkill. And the holders and gizmos that fit 1.32" OD pipe are EXPENSIVE.
The bases for this size pipe are large and have big bolt holes.
I didn't think about the attachment points. The front legs are basically just riding on the bow skin. I cringe when I watch it flex.
The rear legs, which attach to the top of the gunwales, go straight up vertically, so at the dock, if the boat rocks a bit, I have a seriously strong pipe leaning toward the dock, threatening to catch anything that sticks out on the dock as I pull in or back away. I should have mounted them further inboard.
A really square structure just looks inelegant. A slight S bend in both aft legs would look much better. But I'd need a good jig to bend them both identically.
http://picasaweb.google.com/lh/photo/cg63lPP38RjArA8USD-brQ?feat=directlink
http://picasaweb.google.com/lh/photo/zf8MjrEHj1GYu8yHhJYRPA?feat=directlink
Hope this helps someone and/or gives some folks ideas.
The bad:
