There`s a guy in Mount Dora, Florida building boat trailers in his back yard you`d better know something about..I got one and it`s not at all what we agreed to...he said it would be aluminum, it was spray painted steel..the two axles are NOT even parallel or in alignment, trailer swings out to side when pulled..not safe to use at all..spring equalizer bracket different on both sides, one hand made from plate steel..hubs are different on both axles, one has nuts, the other has bolts..winch post is welded so tongue weight can`t be adjusted..holes and mysterious welds all over the frame, looks like it was put together in junk yard..as is where is NO GUARANTEE and NO REFUND. I had uship deliver it so didn`t see before I bought..hard lesson about trusting someone...learn from my bad decision.
