Cruise Craft Restoration
Dunaruna
Re: Cruise Craft Restoration
$660 including all the fitting hardware? That's sounds like a good price! <br /><br />What are you going to use as a sealant?<br /><br />Aldo
tengals123
Master Chief Petty Officer
no fitting hardware, I need a couple dozen s/steel bolts and nuts. As far as the sealant goes, i old one didn't have any. I have quite a large recess that the screen bolts to so there's not much chance of water getting under the sheild and up over and down the dash. But, you've got me thinking, maybe I should use some sealant. Like selleys water tight or window sealer??? They are quite flexible and clear.<br /><br />cheers
Boomyal
I'd use a sealant tengals. It'll keep water from sitting between the glass and the window frame.
tengals123
good point, very good point, I shall investigate weather or not they do that during manufacturing or not.<br />cheers
AMD Rules
Site was down previous 24 hrs period (or so).... looks like it is back up.
tengals123
thanks guys, seems to be working fine today.<br /><br />cheers
Dunaruna
The last 2 pics don't show up tengals, just the dreaded red'X'.<br /><br />Aldo
tengals123
fixed now dunaruna, dont know what happened. cheers
tengals123
yep, 1 done with a saw while cutting the floor. Stupid me The other was a 'previous' owner runaground. Now, before you say anymore the saw cut has been done with epoxy resin and will have 3 layers on it. The crack has been filled with epoxy and that section will also have 3 layers over it. The crack is only a inside surface crack, it does not show on the outer of the hull. Also, for the outside of the hull in that whole section, it will be cut back and re glassed. Pics to follow.<br />cheers
tengals123
also my control box before and after......<br /><br />before------><br /><br />
<br /><br />after------><br /><br />
tengals123
close-up of control box. A super job, thanks goes out to 'tinkerer' on this one. cheers<br /><br />
tengals123
I cant believe my floor is starting to look like a floor again.<br />cheers
Indymike
Hey tengles ...Are you gettin' any sleep? Looks like a lot of work done in the last month.
tengals123
yeah, i know. It's addictive, i can't stop. Im heading to Singapore today for a week (business), so it's going to put me a week behind. It's the painting/surface prep that's going to take a while. I decided to 'roll and tip' 2 part international 'perfection', rather than spray 1 part internation 'brightside'.<br />cheers
Boomyal
Originally posted by Indymike:<br /> Hey tengles ...Are you gettin' any sleep? Looks like a lot of work done in the last month.
When are we gonna see some updated picture for your project? Snow must be melted by now/
tengals123
Sorry guys, I just got back from singapore. Will be installing the floor this weekend. Then I'll post pics. BTW boomyal, It doesnt snow where I live :p <br /><br />cheers
