Crownline 266 ltd 454 7.4L GL volvo penta duo prop. The boat fires up and then it stops. I can not restart it. It does spray gas into the carb when I press the throttle down. It happened a few times before but would fire up after 15 or 20 minutes. This last time nothing. I just changed the spark plugs, rotor, cap and awaiting new wires. Recently changed the oil and replaced the fuel/water separator. I added the stabilizer and added dri fuel to the tank. I would like to know how to test the fuel relay, fuel pump etc... prior to just purchasing and replacing expensive items. I can find alot about the mercruiser but not much on the volvos. any help and suggestions greatly aprreciated. Thanks in advance.
EDIT: 7.4GLPHUS
EDIT: 7.4GLPHUS
