Cranking or dual-purpose
Searay 150merc
which battery do you use? is there a big difference Im trying to figure out which one to buy
escapade
Re: Cranking or dual-purpose
alot of people use two batteries a deep cycle for accessories and have a cranking battery for........cranking.
Depending on the size of your boat and the accessories two would be best but if you only go with one make sure you have a booster pack close at hand just incase
Searay 150merc
Thankyou for your reply, Don't really have any acc. to run just the radio when at the sand bar. I think I will go with the cranking battery with the jump pac for a back-up
Bob_VT
Interstate Dual Purpose one battery :)
escapade
dual purpose because it will enable cranking and be able to power the radio, but a def plus on the jump pack!
Searay 150merc
Thanks on the dual purpose suggestion can you charge these kind of battery's with a regular 10 amp charger or does it need a trickle charge or does the motor charge both?
Searay 150merc
Thank guys found the answer in the electric section.
