Crankcase creates vacuum?
chubcobear
Does the crankcase create a vacuum for the return of fuel mix in the recirculation system? (J90TLCUR) Two one-way valves (below top carb) feed one return line starboard side which goes into crankcase. Does it suck the fuel mix in? Thanks.
F_R
Re: Crankcase creates vacuum?
Not familiar with that particular motor, but yes, there is a vacuum in the crankcase of any two-stroke when the piston is on the up-stroke. The vacuum alternates with a pressure on the down stroke of the piston. That vacuum/pressure cycle is essentional to a two stroke being able to run.
The one-way check valves you mentioned are evidently to let it "see" the vacuum pulse and block the pressure pulse.
ezeke
That's correct for your engine except that there are 4 recirculation check valves in the intake manifold rather than two; one for each cylinder.
chubcobear
F R and ezeke thank you for the info. Yes, there are four. I am only re-hosing the upper two (going to starboard side) because the hose was brittle and cracking. I wanted to make sure fuel/oil mix was going to get sucked into the crankcase. Two upper feed to a "T" and then single hose to the CC.
