Gary H NC
Thread starter- Joined
- Dec 1, 2005
- 8,972
Any Briggs and Stratton techs?
Got a 16.5 hp Briggs motor that started acting up.First it would only run with the choke on. That led me to changing fuel filter,air filter,spark plug and draining the float bowl,cleaning the carb.
Now it runs better but if i try to engage the pto for the blades it dies.
The lever that engages the blades has some kind of electrical switch that releases when the lever is lifted.I found out if i hold that switch closed with my finger the blades engage fine and it stays running.I thought i would unplug that switch and get away with finishing the yard. No luck,with it unplugged the engine will not even start.
So does anyone know why that switch would be telling the engine to shut down?
Thanks
Guess i need a factory manual...
Thanks
