baytonemus
Thread starter- Joined
- Jun 23, 2010
- 217
I'm trying to decide how to repair some cracks in the hull braces on my CL 1960 Flying Crest. These braces are below the front console under a small section of decking where the feet of the driver and front passengers would rest. The first image is a close-up and the arrows indicate the cracks near a couple of 5/32" rivet holes. The second image shows the position of the brace. This whole brace could be removed for repair, (if it's really necessary).
This next image shows a much larger crack in one of braces that serves as a "floor joist." This one would be MUCH more difficult to remove - ~40 rivets including some partially obscured behind the transom.
I've read lots of ideas on this forum about whether or not to weld such thin aluminum hulls. The thinking seems to be it should be avoided unless there's a gash or similar that has to be patched. However, I have a little experience with HTS-2000 low temp brazing rods made to repair aluminum. The working temp is about 725?F, so it's much better suited for working with thin sheets. Heavier pieces of aluminum require MAPP gas, but for something like this you can actually use a propane torch.
Before I go ahead with that, though. I wanted to see if anyone had used HTS-2000 for similar repairs, or possibly might have some other suggestions. Thanks!
