Cracked Sea Doo challenger hull
Woodonglass
Re: `98 SeaDoo Challenger hull repair...question and updates
Mazjag In your how do I get it off the trailer thread your last post was of pics of the Major damage to your hull with questions on how to fix it. Yacht Doctor and I responded. There was No Need to start another thread. If you would have read and familiarized yourself with the forum rules you would have understood that. If anyone is being rude, it is you. You are being given good, sound advice on the actions needed to repair your boat. If you don't want to listen and follow that advice, that is your choice. Good luck with your project.
mazjag
I agree with all that, my bad...The advice was great..Like I said I`ll see what I can do with it or maybe it sinks...Jason
oops!
mazjag, ( and all other people who are looking at this post) .... the reason we dont start two threads on the same boat, is because it gets very confusing to properly reply to a question, and to keep the OP on the right track.
for example... the link in my sig is the largest thread on iboats....it contains, enough discussion to start over 2000 different threads on different subjects, like how to repair a hull how to flip a hull, how to pull a motor.....how to replace a windsheild......ect ect.
if they were all in a different spot on the forum, there is no way, that the person asking a question could properly get helped.
this is also a very family oriented forum, and it is not like other internet forums where people yell at each other and bash them....
the posters on here,,,,,take thier time and extensive knowledge with out payment to them to help you fix a boat properly. with out spending the 6 thousand dollars it would cost to repair you hull by a professional. YD is a pro,,,,as am i ....woodie (though he does not repair boats for a living), has been on this forum long enough and fixed enough boats to hold a doctorate university degree in boar repair.
we are all here to help you.....and we will.
that is one of the super things about this forum......it is all about helping others with out asking any thing in return for the time or knowledge they give !
ok......on with the repair....
First off.......to all the people that read this.....
this was a failed repair by an auto body shop. this is one of my pet peeves.....auto body guys doing boat hull repairs.
the reason for this is because while the basic repair is the same as a car......the products and the ways to do it are totally different, the boat goes through tremendous stresses.....the car does not......the boat lives in a tremendous hurricane when "at work", the car does not. in fact ...the only time a boat lives like a car, is when its on a trailer !
the auto body guys just "do a body job" and think its good.....its not !
ok....all threads merged, but i think one disappeared ??? there was three last night during the server back up.???
as YD and woodie mentioned.....this is an inside out repair......that means that it must be repaired from the inside of the boat, and the out side as well.....you need to do this for structural integrity.
so.... as i mentioned earlier.....you will need to get to the bottom of the hull on the inside.... this might mean pulling the motor....it might mean cutting open the seat well......but you have to get in there to do it.
when you have opened the hull enough to get easy access to the inside repair area.... grind off all the flow coat that is covering the glass. you need to get down to the fiberglass before you can start to laminate to the hull.....if you do not do this.....the new glass will not have a good enough bond to the hull......and the repair will fail......just like it did before.
once that area has been ground down,, and vaccumed and cleaned with acetone.....you can start the repair.
from the out side........
take thin cardboard....and cover it with wax paper.....bend the cardboard to the shape of the missing strake.....kinda make a "shape" of the missing hull....and tape it securly to the hull.
from the inside......
using VE resin......lay one layer 1.5 csm matt over the area....only go one inch over the edges of the repair (your grinding should be at least 4 inches from the edges)....and glass it into place......let fully cure till hard.
after cure.....scuff new layer with 60 grit paper....just scuff off any extra resin....and globs of cured resin...vacuum, and clean with acetone.
add another layer of 1.5 csm.....then a 1708.
now cut another 1.5 one inch larger then the first, so it goes one inch up the hull all the way over the last layer of 1708. glass that in with another i1708
do the same thing again.....make the csm larger than the last 1708 layer and glass in another 1.5 and a final 1708.
so you will have three layers of csm/1708. each layer larger larger than the last. let fully cure.
remove cardboard.......
grind, clean, and acetone the area ad before.....this time when you grind.....start to shape the very first layer of csm which will be hard fiberglass now.....by grinding off any "wows" that stick well out side the hull line....
now add 2 layers of 1.5 csm....and a 1708 and a final large layer of 1.5 csm. over the whole area. this layer should cover the entire ground off area and cover the repair area by at least 2 inches.
let cure.
after cure.......fair the glass......
then gellcoat, sand and buff.
for gellcoating instructions.....just follow the advice in the sticky at the top of the forum.
if you do these steps correctly.....the repair will not fail.....and if your finishing work is good......you wont even see it !
there ya go....
cheers
oops
oops!
Re: best way to get boat off trailer on to its side
I`m not sure that the inside is an option. you can`t get to about a 1/3 of the chine even when you remove the front floor piece. how thick is the hull at that point BTW? open to ideas? thanks...Jason
if the inside of the boat is not an option.......take this boat to a pro...or scrap the hull.
i have fixed enough challengers to know that you can get in there.
mazjag
Thank you Opps! I appreciate you taking the time to type that all out as you didn`t have too..Also my bad if I messed forum rules and offended anybody..Here is the problem I think..I`m in way over my head...I can fix stuff no problem, but I have never fixed anything like this and have zero fiberglass experience...I read your repair post and honestly it looks Greek too me.. When I do peek inside the hull I can see no part that looks like its in the area of where I`m working on the outside..It looks like I would have to grind through layers of gray fiberglass stuff(flowcoat?) to get that area. I don`t see wood stringers, but large gray humps of FB on the strake and chine. Thats why I don`t want to go cutting into the inside..I have no clue..I have tried to look on youtube to see how hulls are built so I can understand whats going on here, but I don`t get it...I see they made a outer shell with the gelcote and all and it looks like they dropped in a sub structure that sits flat on the strakes and it glued in some places..The whole part from the strake down to keel seems to be spaced with foam...I`m not totally dumb and if I had a better idea what I was up against it would help...anybody got a link?? the forum is great and people are helpful...I`m the dummy....Jason
GT1000000
Re: Cracked Sea Doo challenger hull
Hi mazjag,
If you take some pictures of what you are lookin at, post them here [use the Photobucket method, it works the best]... and are willin to give it a try, between oops! and the rest of the guys here...they can help you out step by step...you just have to be willing to get a little sweaty, dusty, bloody, and frustrated...in the end you will end up with a perfect repair, a great working craft, and a whole new knowledge base...
Best regards,
GT1M
mazjag
Thanks GT, no doubt...I have already gotten all those things including slightly pissed off. I didn`t tell the story how it almost sank with my two nephews aboard...Bildge pump was new and came on but I guess sucked up a gum wrapper..You ever pump out a boat manually with a seven year old trying to make the outlet hose spray with his thumb..I have! Jason
Tail_Gunner
Greeting's Mazjag looks a bit nasty there. If you take the time to follow Opps and a few other's you will get it done. The absolute hardest part is the intial destrcution along with the unknow and uncertainity. Once your on the repair itself it all down hill....By the way some of these guys are not your weekend tinker's....There very accomplhised pro's. Fiberglass is a kick once you understand how easy it is.:D:D:D:D.....Some of them just could not let well enough alone so they just cut there boat in half...:eek:.. and glued her back together...:cool: That person is more than capable to guiding you thourgh this little rasberry.
mazjag
Thanks, I saw that when I saw somebody make a boat longer..I really just want mine to float..Jason
GT1000000
Bummer, No I haven't been in that situation, but I was about 3 miles from the dock when my engine decided to release all of its factory smoke and I had to oar my way back...
I hope you can get it taken care of, it sure is cheaper than havin to buy another, and you'll know for sure it is done right...
As always, The best of luck...
GT1M
Yacht Dr.
Maz man.. I know how you feel .. I really do.
You see.. them little jet boats are kinda high tech machines that are slightly different in their builds.
They have a molded hull..molded stringer system..and a molded decking.
They bond the stringer into the hull..then cap the deck ( Im not sure if your deck is bonded to the stringer/hull system ). If it is..then your boned. You will never get that Plexus apart.
Basically what your looking at from the outside is through the Hull and into the Stringer system..if you keep grinding your going to hit the deck system. Its ALL INTEGRITY Together. Not each one seperate..they work together making a light boat ( yea and that beer cooler foam is there for a reason too.. ).
These are Very technical Repairs and I suggest you have it looked at by a Pro.
Yea just getting the Motor out is a pain and wires and so-on.. Its a big job.. Alot more then 3k for a reputable repair shop.
Do you have Insurance ?
YD.
mazjag
Its actually two motors and a 40 galllon tank. I do have insurance but I had a guy at the shop the other day and he used to be head of marine repair for progressive. He said he would kick that back out as manufacture defect. glad to see you know whats up with how its built..Like a jet ski with molded inner structure...Love the boat! it handles great and everything is working with two reman. engines and rebuilt jet pumps..it scoots when it floats..J
Yacht Dr.
Ok... so what are you going to do ? ...
Investigate more or ... ? ..
We want to help..but we cant really help at the moment with what your doing and how your doing it..
Got to have a breaking point here son..
YD.
mazjag
I`m gonna try and remove that front piece and get into that molded stringer system you speak off...Maybe if I can see it better I can get a better grasp of it...thanks..J
Ayuh,.... So,.. Have ya pulled the motors, 'n tank yet,..??
With these kinds of repairs, Big destruction has to happen, before reconstruction can start...
mazjag
After messing around and pulling some foam from the front storage compartment I can see the problem...That inner structure piece has about 3 broken junctions inside when I look around...see pics.. cut hole in the floorboard as I couldn`t get the screws loose on that piece under the glovebox..stripped screws...2 questions...1.) what do I use to fix that grey nasty fiberglass with? 2.) when cutting access holes is there a best way to do it to make less work..Do I cut a circle or square ...with a bevel like a pumpkin lid? thanks.JasonPhoto069.jpgPhoto071.jpg
After messing around and pulling some foam from the front storage compartment I can see the problem...That inner structure piece has about 3 broken junctions inside when I look around...see pics.. cut hole in the floorboard as I couldn`t get the screws loose on that piece under the glovebox..stripped screws...2 questions...1.) what do I use to fix that grey nasty fiberglass with? 2.) when cutting access holes is there a best way to do it to make less work..Do I cut a circle or square ...with a bevel like a pumpkin lid? thanks.JasonView attachment 148626View attachment 148627
Ayuh,.... More pictures,.... Sometimes ya cut out Whole sections, it's easier than little holes....
Yer gonna need a 4" grinder, 'n some disc's....
I cheat, 'n use epoxy resins,.... it's alittle more "Forgiving" than polyester resins...
mazjag
Do I just grind a v in the crack? Don`t I have to put some glass on it as well? I would cut one big one, but the 3 breaks are all at different points in the hull..Now I`m inside the hull and I`m gonna take care of my other crack on the strake from the inside as well..Just like everybody has been telling me..I would have more pics, but it was hard to take them with a phone and provide light.thanks,,Jason
Yacht Dr.
So you cut a section of the stringer system out then ?
As bondo said..please more inside pics :) ..
YD.
mazjag
Oh no, But I removed some floatation foam from the storage compartment and I can see a crack ,actually 3 cracks were the ribs join the stringers...see pics.. The material looks like about 1/8" thick covering a foam core..Do I just grind it down, clean and layer it on? Should cloth, mat, or rove be used on something like this? you can see the crack on one in the pic of the inside of the hull..its to the right..thanks..JasonIM001654.jpgIM001655.jpg
