Crack in Aluminum boat
EMW73
Hi guys looking for input. I have a 15' aluminum flatbottom boat that I bought over the winter and I was rewiring my trailer when I noticed a small bulging crack in the front side of the boat. Without getting into cutting and welding I was wondering if my best bet was to wire brush down to metal then tap the bulge in and fill it with marine grade JBweld. I'll try and get a picture so you see what I'm working with. Looking for other ideas for a fix.
Thanks.
EMW73
Re: Crack in Aluminum boat
Ps can't do anything to the inside because it is carpeted.
robert graham
Above the water level maybe JB Weld, below the water level I'd get it welded on the outside....a good welder can run a nice bead right on that crack in just a few minutes...
GT1000000
You could apply a aluminum patch piece sealed with 5200 and rivets...
lckstckn2smknbrls
First you need to drill a hole at each end of the crack to keep it from getting longer. I would get the crack welded but more importantly why is it bulging?
EMW73
There was some water in the front storage witch is where the crack is so I believe the water froze and created the crack. JMO!
EMW73
My uncle is a welder and I talked to him and he is going to look at it. I wanted to try to fix it on my own with the JB weld because I don't like asking for favors but after hearing all the input I asked and he is going to look at it. I just want it to get it fixed the right way so I can worry about how much fish I will catch and not how to get in the water! So thank everyone for your input!
