Barry63052
Thread starter- Joined
- Jul 10, 2013
- 30
Ok, I have an 1991 18' bass buggy with a 1991 Evinrude 40 horse. The model number on the motor is TE40ELEIA. Well, now that we got all that out of the way....
I just got the boat a couple of weeks ago. Everything seemed to be pretty good with it, needs redecking, but mechanically sound. Two weekends ago, it had a little melt down. It seems that the auto style driving lights that somebody else had hooked up over heated the ground wire. It melted the wire behind the dash and down to the plug. See this thread: http://forums.iboats.com/pontoons/new-boat-new-problems-615934.html
I went back to the boat last weekend and rewired everything that was bad, but didn't get a chance to try it out.
Put it in the water this weekend and everything worked, kinda. The tach was acting strange, Saying that I was at 2000 rpm's even though I was only idling, dropping to 0 rpm's at wide open throttle, ect. So, I got on here and found out that the tach runs off of the electrical current. And if the tach stops working, the first thing to check is the charging of the battery. So, I did just that. Found out I was only at 11.88 volts while running. So, pull the boat out of the water, again.
Get the boat back to my lots, take the hood off and start looking for anything obvious. Mind you, this is my first boat ever and know next to nothing about boat, but I did find a black box looking thing on the side of the motor that was loose. Figured it wasn't that big of a deal, but decided to tighten it up any way. Take the two screws off of the top of the cover, remove the cover, and WOW, that's a lot of wires and stuff in there! Then, I get to looking, and there is a black bar looking thing with some screws hold wires down, and the red one is fried! Insulation is burnt off of it and even broke in two! Again, Im NOT a boat mechanic, but even I know that's not right!
So, I take out this thing, come back on here, and figure out its a rectifier! And the rectifier not working will make the tach mess up and not charge the battery. So I think I found and solved the problem. I just wanted to run it by the experts on here and see if you think I am on the right path.
Also, do you think the rectifier went out and caused the short with the ground wire? Or the lights caused everything to over heat? Or have any other ideas?/
