Could this be a lean condition?
Cricket Too
I have a 1975 Johnson 70hp that I was fogging for the winter this past weekend and while taking the plugs out after fogging, to shoot fogging oil down the plug holes, I took a look down each hole at the piston head just to get a rough idea of what kind of carbon build up was on them. Anyway when I looked down the #3 (bottom) plug hole the piston head looked noticeably cleaner than the other two. Could this be caused by the #3 carb running lean? The plug did not show any signs of the cylinder running lean, it looked the same as the other two plugs, pretty wet with fuel and oil. There is also no water leaking into the cylinder so I don't think that is what is cleaning the piston head. The motor runs perfectly with no problems idling and no problems at WOT. Could it just be that that piston is just cleaner and nothing is wrong? Thanks, Mike.
D
DJ
Guest
Re: Could this be a lean condition?
mmcpeck,<br /><br />A clean piston is usually the sign of water ingestion, however small that amount may be.<br /><br />If anything, the bottom cylinder will get more fuel than the top two. It also runs the coolest. More fuel can also have a cleansing effect.
Cricket Too
djohns19....So do you think that the bottom cylinder is just getting more fuel and is a little cleaner because of that? I have seen cylinders with water intrusion and seen how clean the piston gets, this bottom piston does have a good amount of carbon on it, it is just that it is cleaner than the other two, it is not completely clean like alot of water intrusion would make it. What is the reason for the bottom cylinder getting more fuel, is just beacuse of it being on the bottom and gravity causing more fuel to go into it? Thanks.
Cricket Too
Can anyone tell me how I would go about telling for sure if I do or don't have water intrusion into this cylinder? If this could be caused by a lean running carb I would like to fix it before I fry this piston. Compression readings are #1-130psi., #2-125psi., and #3-124psi.. I don't think I have done any damage yet. I guess if a rich running carb can do this I might as well just tear the carbs down and put kits in them, it's been a couple of years, at least it will give me something to do. Thanks.
Stumpknocker
Just info ref clean piston. I changed my plugs yesterday and like you peered down into both bores to see the top of the pistons. I have a 2 cylinder 48HP engine. The top of both pistons looked like they just came out of the box. This is a 1995 engine. Runs great and does not have any water ingestion. I use this engine in salt and freshwater. It has never given me a moments problem. <br /><br />However, why you have both a clean piston and some that appear carboned is strange......
D
DJ
Guest
mmcpeck,<br /><br />The boittom cylinder getting, potentially, more fuel has always been a theory of mine. Fuel tends to puddle in the bottom of the crankcase.<br /><br />Your compresdson looks good. <br /><br />It certainly won't hurt to put carb kits in it.
wilde1j
Look at the spark plugs ... one with water ingestion will be clean as a whistle, w/o carbon.
