Cricket Too
Thread starter- Joined
- May 14, 2003
- 1,732
I have a 1975 Johnson 70hp that I was fogging for the winter this past weekend and while taking the plugs out after fogging, to shoot fogging oil down the plug holes, I took a look down each hole at the piston head just to get a rough idea of what kind of carbon build up was on them. Anyway when I looked down the #3 (bottom) plug hole the piston head looked noticeably cleaner than the other two. Could this be caused by the #3 carb running lean? The plug did not show any signs of the cylinder running lean, it looked the same as the other two plugs, pretty wet with fuel and oil. There is also no water leaking into the cylinder so I don't think that is what is cleaning the piston head. The motor runs perfectly with no problems idling and no problems at WOT. Could it just be that that piston is just cleaner and nothing is wrong? Thanks, Mike.
